Cam Shaft Endplay
Old Nov 7, 2023 | 04:28 PM
duluthsound's Avatar
Default Cam Shaft Endplay
In the process of rebuilding 4.6
I have read the RAVE manual regarding cam Endplay but thought I'd get another opinion
​​​cam gear is fitted to camshaft, doesn't seem like it mates up all the way with the bolt tight. New cam gear, new chain. Original camshaft
Cam shaft as considerable amount of play. Rave says to replace thrust plate but I don't see any wear on it.
Video attached
https://drive.google.com/file/d/1DRo-fF3CGDW5lXRvD8ryVprve_jnsG1_/view?usp=drivesdk
Old Nov 7, 2023 | 06:08 PM
Alex_M's Avatar
Some end play in a cam is normal. All the loves are worn with a taper which is meant to make the lifters rotate, but it also pushes the cam backwards. Small block Chevy's didn't even used to have any form of cam retention, so end play is really a bit of a non issue unless you've got some kind of strange wear.
Old Nov 8, 2023 | 08:19 AM
So are you thinking this amount of play is ok? The thrust plate looks fine and I don't see any visible wear on cam or bearings.
Llamasayswhat
Sep 16, 2018 11:14 PM
robert.juric
Jul 19, 2017 03:57 PM
ForTex
Jun 3, 2016 09:41 PM
BCDisco2Lando
Aug 7, 2013 10:19 AM
MrFlea
Sep 7, 2011 02:22 PM
