LR II Cam shafts
Old Sep 6, 2011 | 07:18 PM
MrFlea's Avatar
Default LR II Cam shafts
I understan that the LR II 4.0 cam shaft are a big question mark. They are suspect to failure. So is there a particular lobe that fails or is it the entire shaft ? I remember that GM had a problem in the late 70's and it was due to the way it was fired when hardened. Just curious if all of the failures were at one point or just a soft cam shaft. Thanks
Old Sep 6, 2011 | 09:18 PM
I have only heard of 2 of them failing and both were due to lack of lubrication.
Old Sep 7, 2011 | 10:02 AM
MrFlea's Avatar
So all this I've been hearing about BAD cam shafts is just bad information ? I am about to pull my 2001 4.0 LRII apart and replace the lifters/push rods and rocker arms. Origanally I was going to replace the valve cover gaskets. but have decided to look at the lifters and stuff and replace what is needed.
Old Sep 7, 2011 | 10:16 AM
Rover has had soft cam issues for along time. They are not lobe related and will first show up as a tick, then a lifter noise based on surface wear of both the cam lobe and the lifter.
It doesn't happen to all engine but can.
Why do you ask?
Old Sep 7, 2011 | 10:51 AM
jafir's Avatar
you should never replace lifters without replacing the cam too.
Old Sep 7, 2011 | 02:22 PM
nevada ben's Avatar
I'm curious because I've been thinking about what might work from the Buick 3800's. Obviously not cams but I wonder about lifters (I know you'd have to machine the block for rollers) and then pushrods, rockers, springs, valves, and also con-rods and pistons, although I understand the crank changed quite a bit. I know it's sort of not-worth-it with how easy it is to drop in an LS engine, but I wonder how trick you could build a Rover V8. I know they raced them in Formula 1 for a while, but those days are long past. I think if you look around UK sites you will find some pretty trick Rover V8's but I doubt the parts are stocked in the US unless they're 3800 compatible. But in the UK, there should be some good heads, cams, and intake manifolds. I imagine the limit is primarily the 2-bolt main bearing caps. Look at these:
http://www.v8wizard.com/photo_galler...hor_engine.php
Tim Lanocha's Triumph TR8 with Rover V8==
Bespoke Design | MG B GT V8 Sebring | Classic Wheels Berlin GmbH
I'm not suggesting this stuff for a Land Rover with a ZF 4HP22 etc. but I'm just curious. For my purposes, the stock 4.0 overpowers the Land Rover for the trail, and I don't drive it on the street.
Core_Shot
May 1, 2017 01:04 PM
ajh
Apr 6, 2010 10:32 AM
jycsalas
Sep 10, 2008 01:04 AM
pennystockart
Nov 24, 2007 03:52 PM
jwb
Mar 9, 2007 09:50 PM
