Camshaft bearings 04 SE7
Old 12-18-2015 | 09:30 AM
WNYErikDiscoII's Avatar
Former Sponsor
Originally Posted by NorCalDisco
Another unrelated question, can you run 37" tires on a rrc? Will the engine be able to handle it? Considering a new project and want to know if it is possible.
Yes, with upgraded gearing and axles. I wouldn't run them on stock driveline.
I recently setup a 1992 RRC for a customer who was going to run 35". HD Front and Rear axles with HD flanges($1300) and I set up his diffs with 4.37s ($350/diff for the gears, $200 to set them up in the diff including new Timken bearings and corteco seals) Add another $900/diff if you want a locker.
  #22
Old 01-27-2016 | 02:23 PM
NorCalDisco's Avatar
Just replaced this engine. The 4th camshaft bearing was gone. The main bearings looked great and I had almost 200k the rod bearings were so so. The cam bearings went out the back, idk if you could replace them in the car.
  #23
Old 01-28-2016 | 06:46 AM
drowssap's Avatar
the cam bearing can be done in the truck but not easily, the last fellow how did them i think had a handle like f150 or something like that he did a post with pix. iirc
G150driver
04-09-2015 06:28 AM
icoolyou
05-23-2007 09:52 AM
icoolyou
05-16-2007 06:50 PM
4x4poland
11-21-2006 09:40 PM
masher
12-31-2005 10:56 AM
Quick Reply: Camshaft bearings 04 SE7
