Camshaft bearings 04 SE7
Old Dec 18, 2015 | 08:30 AM
  #21
WNYErikDiscoII's Avatar
Former Sponsor
Originally Posted by NorCalDisco
Another unrelated question, can you run 37" tires on a rrc? Will the engine be able to handle it? Considering a new project and want to know if it is possible.
Yes, with upgraded gearing and axles. I wouldn't run them on stock driveline.
I recently setup a 1992 RRC for a customer who was going to run 35". HD Front and Rear axles with HD flanges($1300) and I set up his diffs with 4.37s ($350/diff for the gears, $200 to set them up in the diff including new Timken bearings and corteco seals) Add another $900/diff if you want a locker.
Old Jan 27, 2016 | 01:23 PM
  #22
NorCalDisco's Avatar
Just replaced this engine. The 4th camshaft bearing was gone. The main bearings looked great and I had almost 200k the rod bearings were so so. The cam bearings went out the back, idk if you could replace them in the car.
Old Jan 28, 2016 | 05:46 AM
  #23
drowssap's Avatar
the cam bearing can be done in the truck but not easily, the last fellow how did them i think had a handle like f150 or something like that he did a post with pix. iirc
G150driver
Apr 9, 2015 05:28 AM
icoolyou
May 23, 2007 08:52 AM
icoolyou
May 16, 2007 05:50 PM
4x4poland
Nov 21, 2006 08:40 PM
masher
Dec 31, 2005 09:56 AM
