Camshaft Finished, bye bye tick tick..
Old Aug 20, 2013 | 08:31 AM
primussucks's Avatar
Originally Posted by earlyrover
"Heads are on my list of this to do, but having the low end knock has scared me away because I don't want to get in there and find slipped liners. This is the exact knock mine makes. Comes and goes, but generally always there." iF your main or rod bearing inserts, especially main inserts are worn enough for knock, as Caymandrew had, the longer you drive it, the more the chances that you will beat flat spots, out of round spots, on crankshaft journals, if not already done, which will cost you a lot more to repair it, to replace crank., or have crank journals worked over by good auto machine shop.
Thanks.
I'm picking up a RRS this week for my daily driver, so my Disco won't get as much use... Mostly offroad use.
Old Feb 14, 2014 | 05:12 PM
dr. mordo's Avatar
Caymandrew, why did you replace the rocker arms? Were there any indications they were worn or was it just to cover all your bases while you were in there.
Inspired by your experience, I'm thinking of swapping cams while I have the heads off in the spring.
Old Feb 14, 2014 | 05:49 PM
Jared9220's Avatar
Very cool thread, but the video is set to private and I can't watch it. I don't know how this one slipped by me, but I'm sold on this rebuild.
A few questions:
1)You do all of this with the heads still bolted on correct?
2)how hard were the main and rod bearings to replace?
3) I to am thinking of doing this very soon, but I have been thinking about using this sport Cam instead of the stock one. Turner Engineering H180 Camshaft Sports Torque (nn) Any thoughts on this cam, good or bad?
Old Feb 15, 2014 | 07:43 AM
caymandrew's Avatar
Dr. Mordo, I didn't have a specific reason for the arms, but if you see the wear on the rocker shaft, I think it's fair to assume some wear on the arms as well. And beside, if you're in this deep why not?
A few questions:
1) Yes
2) Difficult but doable, follow master rover techs thread in the how to section.
3) Not sure, I went with an exact replacement so I didn't research any other option.
The important thing to note in all of this is that, in order to get the camshaft out you need to pull the radiator, trans cooler, oil cooler (if installed), and A/C compressor lines. If you're adventurous like me, you can lay some blankets on top of the engine and pull everything up gently fold the radiator, trans cooler, etc backwards and put on top of the engine to get camshaft out. (This way you don't have to deal with those Trans cooler lines that are a bitch!). Just be very careful not to puncture your radiator on any sharp edges. However, there is no way around disconnecting the A/C lines. We all know that's illegal to do in your garage and up to a $10,000 fine in most places. So have the A/C system drained at a shop before you begin this project, and just fill it back up at home once you're complete. Good luck!
Old Feb 15, 2014 | 08:25 AM
04duxlr's Avatar
Replacing the rocker arms is a very good idea when doing this much work. The rockers are softer than the shaft, but they start to wear out the shafts as they get older because any metal in the oil can get embedded inside the rockers on the bearing surface. The bearing ends up becoming a grinder from the little hard particles. The metal that was your rod bearings would be a perfect source.
When the shafts are replaced, the rockers should be replaced also for everything to last as long as possible.
Old Feb 15, 2014 | 08:51 AM
dr. mordo's Avatar
Thanks for the answer. I didn't realize you had to disconnect the radiator and coolers. That's certainly a PITA. I knew the radiator would come out but assumed the trans cooler and condenser could stay in.
Old Feb 16, 2014 | 09:55 PM
Jared9220's Avatar
1) Yes
Thank you for the response and advice.
lipadj46
Apr 20, 2010 12:59 PM
zracin
Mar 7, 2008 01:17 PM
Darover
Sep 22, 2007 09:24 PM
97XD
Feb 2, 2007 07:46 PM
Randy Lover
Nov 1, 2005 04:39 AM
