Camshaft Position Sensor
The crank sensor controls spark.
The cam sensor controls injector pulse.
If the inertia switch is tripped it is supposed to kill the fuel pump only.
Reset the inertia switch, press it for 3-5 seconds and then try and start the truck.
The inertia switch is on your firewall, it trips if you hit a big enough bump,
It is a black rubber button next to you washer tank, button on top.
p0317 is a rough road fault, also. & your symptoms remind me of it tripping, it's free and easy to check, just push it down.
It's worth trying.
It's worth trying.
thanks
Do you know what causes no spark and no injector pulse?
Helps please. (:
Yes, yes and yes. Relays are under the kick panel on the passenger side. They are a standard Bosch relay. The ignition module is under the steering column/dash panel and hooks into the fusebox and the ignition (back of the key).
oh if you suspect flooding hold your exalarator to the floor it will give half fuel untill in starts ?
Thanks justs though I would answer, if they are still alive? And for anyone who may search this question as it hasn't been answered for a while lol
DeepBlueWater
Nov 22, 2019 07:51 PM
