Camshaft Position Sensor question
Old Aug 29, 2018 | 04:12 PM
darkaegis's Avatar
Default Camshaft Position Sensor question
Do I need to remove the crankshaft pulley to replace the camshaft position sensor or will removing the fan and serpentine belt be enough to get access to it?
I have the RAVE manual, but looking at the pictures it looks like they reference the replacement as if the crankshaft pulley is removed but it doesn't say it needs to be removed... inspection from below kind of indicates at least the fan and serpentine belt need to come off.
Thanks ahead of time.
Old Aug 29, 2018 | 04:28 PM
redwhitekat's Avatar
I believe it's on the drivers side kinda hard to get to but patience
there is a cover you remove cover then remove bolts to sensor and pull it out
lots of info on this forum for this job just search
Old Aug 29, 2018 | 04:36 PM
darkaegis's Avatar
That's the crankshaft position sensor... I know because I replace the WRONG one last week Well... I should have double checked the manual as there are two (crankshaft / camshaft)
Old Aug 29, 2018 | 06:09 PM
Extinct's Avatar
Pretty sure all you need to do is remove fan and water pump pulley. Why would you replace it? They almost never go bad. Correction, I have never heard of one going bad.
Old Aug 29, 2018 | 06:29 PM
darkaegis's Avatar
My daughters rig has 197k miles on it.. which was formerly my rig, so she inherited the mechanic also.
With a check engine light on for the camshaft position sensor. I will remove the water pump pulley and see if I get more clearance.
I updated to a 2008 RR HSE (non-sport, full RR) which is really nice but I still like the fact that I can hit stuff with the disco and not worry about it.
Old Aug 30, 2018 | 01:35 PM
Extinct's Avatar
It goes reverse in my family, Dad inherits the high mileage rigs. Could probably get it off without removing the water pump pulley now that I look at it.
Old Aug 30, 2018 | 03:02 PM
darkaegis's Avatar
Wow! I really appreciate the picture, I will take a stab at this this weekend.
Old Sep 2, 2018 | 06:36 PM
darkaegis's Avatar
Well.. for those that have to do this work. Ignore the manual, it says remove it from the bottom which may work if you have a lift. But you really can't see the sensor, so do it from the top. You need to remove the fan, serpentine belt and fan pulley, the fan is a 36 mm wrench which comes like a standard nut and you can use a couple of screwdrivers to form a brake to keep the fan from moving. Then pull the pulley off using the same method, but rest your socket wrench on top of the shaft of the screw driver. You will need a 15 mm socket for the serpentine tensioner, a 12 mm for the fan bolts and a 8 mm bent wrench to get to the sensor bracket. The sensor connector slides on from right to left on a blade bracket just above the flywheel.
Works like a charm.
Old Sep 2, 2018 | 08:01 PM
The Deputy's Avatar
Pretty nice, "Extinct" pulls and disassembles his engine...just to show you where it's at. I'm a nice guy, but even l wouldn't do that...lol.
Brian.
hrhoward
Sep 17, 2019 01:39 PM
patd
Apr 28, 2017 11:56 PM
wdelacru1
Oct 20, 2016 04:01 PM
mirepoixmatt
Feb 14, 2015 07:59 PM
lacruiser
Feb 28, 2008 07:24 AM
