Camshaft Sensor Fault?
Old May 31, 2023 | 08:26 PM
owen.calder's Avatar
Unhappy Camshaft Sensor Fault?
Hey all my nanocom has recently diagnosed my Disco 2 v8 with a Camshaft/Timing error Fault. It reads as follows
P1000 = Camshaft Sensor Fault/Valve
Timing Error Drive Cycle A
Occurred 1 Times
Signal Invalid
Fault is Currently Present
I have Changed the camshaft sensor but still the fault remains
Any help would be appreciated
Old Jun 1, 2023 | 12:06 PM
Motorhead1's Avatar
Check the wiring at the plug.
Old Jun 1, 2023 | 06:49 PM
I will and should’ve while i had it out
Thanks
Old Jun 2, 2023 | 11:24 AM
Motorhead1's Avatar
After I finished an oil pump/head gasket job, I had a code saying the cam sensor was not functioning or no signal, I figured it was the sensor, but it turned out while I was pulling wires and loom back out of my way during the head gasket/oil pump job, I apparently pulled on the cam sensor loom plug wires too hard which resulted in one wire not making a connection to the cam sensor when plugged back in. I was able to push the one wire back into the plug, easy fix, but through me for a small loop.
emkg
Nov 13, 2021 05:33 AM
mx468
Mar 29, 2018 04:43 PM
krammark
Sep 15, 2016 10:15 PM
Lupin 3rd
Nov 27, 2012 12:34 PM
sharp
Feb 5, 2009 09:11 PM
