Can’t get my lug nuts off....
Old Sep 28, 2019 | 01:51 PM
Carlos Man's Avatar
Default Can’t get my lug nuts off....
Umm.... I can’t get my lug nuts off my D2.
I've literally stood on the tire iron and jumped up and down and they don’t move at all.
am I doing something wrong here??
Old Sep 28, 2019 | 01:58 PM
Friday Night Disco's Avatar
I use a pry bar, if you do not have a pry bar find a pipe and use it over the tire iron as a cheater bar
Old Sep 28, 2019 | 01:59 PM
zuke's Avatar
Lefty Lucy
Righty tighty
Old Sep 28, 2019 | 02:00 PM
Originally Posted by zuke
Lefty Lucy
Righty righty
Tire iron does not have enough leverage
Richard Gallant's Avatar
@Carlos Man You are not but some other idiot was way over torqued. I suggest a tire shop with an impact gun, or a long breaker bar to get them loose then about 85-100 lbs of torque when you put them back. Check after your 1st drive just in case and you are done.
Old Sep 28, 2019 | 03:21 PM
Carlos Man's Avatar
Lefty Lucy
Righty tighty
funny...
Old Sep 28, 2019 | 03:23 PM
Carlos Man's Avatar
I’m gonna order a 1in impact socket and put a pipe on my breaker bar. See if that helps at all.
im also soaking them in WD40 right now.
if not I guess I’ll go see a tire shop with a impact and have them loosen them up for me.
ive read on here just now even some impact wrenches have failed. Getting kinda worried.
Old Sep 28, 2019 | 05:26 PM
shanechevelle's Avatar
An impact will ruin the stainless cover causing you to buy new lug nuts. It rounds them off.
Get a socket and a breaker bar, place the bar at a horizontal position and place a Jack under the bar or pipe. No heavy work needed.
Also, keep the truck on the ground to help break them lose.
Old Sep 28, 2019 | 05:31 PM
Another way....which isnt my favorite, is to place a lug wrench onto the lug and then drive forward or reverse.
Only use in extreme life threatening situations like a gun fight in a combat zone. Perform task slowwwwwly.
Old Sep 28, 2019 | 06:14 PM
mollusc's Avatar
don't use an impact device. you need to be able to control the torque. get a breaker bar and a socket, and extend it with a piece of pipe if necessary. i had to use a 5' length to get some of mine loose when i first got it.
the reason i recommend not just attacking it with an impact wrench is that the studs can break free in the hub and start to rotate, and then you're really screwed. i had to literally cut one of my wheels off when this happened.
