Can’t get my lug nuts off....
Old Sep 29, 2019 | 05:09 PM
  #21
05TurboS2K's Avatar
Yayyyyy!!!!!!
Old Sep 29, 2019 | 05:30 PM
  #22
mln01's Avatar
Be sure to clean off any WD-40 residue. You do not want that on your wheel studs and lugnuts. I understand using it to get them off, but be sure to remove it now.
The factory torque spec for the lugnuts is 103 lb. ft.
Old Sep 29, 2019 | 05:38 PM
  #23
Carlos Man's Avatar
Uh oh... I soaked them good. Plan on installing my lift Saturday.
Old Sep 29, 2019 | 05:58 PM
  #24
05TurboS2K's Avatar
A little brake clean, carb cleaner, gasoline, even simple green, sprayed on the studs will be fine to clean it off. They don't need to be perfect just give em a squirt with a cleaner or even some simple green and call it good, a little won't hurt, a lot of lubrication however effects the tq values and with heat cycling can actually make them harder to remove. Only in extreme circumstances like a mud rig would I lubricate the studs.
philwarner
Sep 1, 2014 02:57 PM
bcolins
Apr 19, 2011 06:40 PM
rsandmeyer@cox.net
Oct 18, 2008 05:20 PM
troubled
Jun 23, 2008 07:18 PM
Camdisco24
Sep 4, 2007 10:34 PM
