Can the 3 amigos be sent away?
Old Jan 8, 2025 | 08:14 PM
Diesel Gypsy's Avatar
Question Can the 3 amigos be sent away?
I would like to part with my buddies, (alias the 3 Amigos) but the "ABS MODULATOR FIX (NO more SVS fault)" link is corrupted so I can't get to the article. Is it written somewhere else that I can read it? Would really appreciate some help here!!! (not very computer literate!) Thanks
Old Jan 8, 2025 | 08:50 PM
Windycity_rover's Avatar
There is a multiple write ups from years ago. Option B is a common fix. I used Option B back in 2011 and sent the Amigos away. System still performs and the 3 Amigos will return. When they do you know something is generally wrong other than a possible 1590 code (Rough Road). Search should provide the write up? If not, I think I have the write up in .pdf.
Old Jan 9, 2025 | 01:31 AM
DiscoOslo's Avatar
It's not a write-up, but I was reminding myself how to do this a few weeks ago and came across this video that I thought was a good summary:
Old Jan 9, 2025 | 08:44 AM
Thanks for the video. It helps to see that but it doesn't actually describe what is being done and why. I guess I'm too old school - I like to see things written down with diagrams! lol
Windycity_rover, I would really appreciate the PDF article if you could find it. Thanks, Jim
Old Jan 9, 2025 | 08:49 AM
Grum.man's Avatar
I used that same video. Pretty easy straight forward job that didn't require any brake lines to be removed. Fixed my problem and saved a bunch of money.
Old Jan 9, 2025 | 09:52 AM
DiscoOslo's Avatar
Fair. I had the old write up, not sure what happened to it. I would say if you do the fix, the crip connections work so much better than trying to soder those wires. I soddered the unit on my old truck and it was a pain, but the crimps were quick and easy. I think 30 minutes in total.
I'll poke around on my old laptop and see if I can find it. From what I recall the switch you cut out doesn't ground properly, and by performing the fix you create a better ground that isn't faulty. But I'm sure someone else could explain better than I.
Old Jan 9, 2025 | 07:15 PM
Extinct's Avatar
Have you checked the fault codes, do you know you have the modulator switch fault?
Old Jan 9, 2025 | 10:28 PM
evil_goat's Avatar
The write up of the Option B shuttle valve switch electrical fix can be found here https://web.archive.org/web/20170730...m/abs-mod.html
I also attached a pdf if that goes down.
Old Jan 10, 2025 | 01:13 AM
disco_rookie's Avatar
Excellent resource! This procedure solved my intermittent “3 Amigos” problem on my D2.
Anthony Brancato
May 12, 2021 07:57 AM
Boats121
Jan 2, 2015 08:31 AM
ImQuattro
Jul 11, 2014 03:57 PM
chicane
Jun 6, 2014 10:38 PM
PaBs00disccovery
Sep 25, 2011 08:12 AM
