Can anyone identify this bolt??
Old Sep 18, 2016 | 07:29 PM
cobbcj7's Avatar
Default Can anyone identify this bolt??
Not a bolt, a nut sorry..
I found this specialty nut in the driveway where I park my Disco2... Does anyone recognize it?? Thanks
I think it goes with something that uses a cotter pin.. maybe tie-rod end or something..
Old Sep 19, 2016 | 01:36 PM
d.a.r.y.l's Avatar
I don't know where it goes but have some observations about the nut. It doesn't go with a cotter pin because none of the notches line up across from each other. I believe it's called a castle nut. The top notched area is crimped in so that it will be tight going on. Something like a lock nut. Wish I could be more help but that's all I know. D*
Old Sep 20, 2016 | 09:56 AM
cobbcj7's Avatar
I thought same thing.. looked like notches for a cotter pin but they don't line up..
Old Sep 20, 2016 | 10:43 AM
OffroadFrance's Avatar
What size (diameter) thread in millimetres? or what size across the flats. It looks initially like the staked nut off the front or rear hub centres. There are no castellated nuts on a D2 only staked nuts. Unfortunately the coin is blurred and so hard to estimate the nut size. If it is a hub nut it needs replacing PDQ.
Old Sep 20, 2016 | 02:30 PM
dgi 07's Avatar
Without the coin for comparison, i would say check your tie rod ends. Is that a quarter?.
Old Sep 21, 2016 | 05:14 AM
Suggestion. Post another photo or two with a 6" rule alongside the nut with the rule graduations clearly visible. Obviously it isn't a castellated nut or a nyloc nut my guess being a stake nut which has been used multiple times and damaged.
https://www.google.fr/search?q=disco...hrome&ie=UTF-8
Judgey
Jul 22, 2013 07:55 AM
ShadowMerchantBC
Sights N Sounds
Apr 19, 2011 10:27 PM
senna
Mar 16, 2011 03:51 PM
MGibbs
Sep 12, 2010 10:04 AM
madas
Aug 30, 2006 11:57 AM
