Can anyone identify the box?
Old Aug 29, 2006 | 11:09 PM
madas's Avatar
4wd High
Default Can anyone identify the box?
Hello,
I have a black box under my dash which has a cable not connected to it. I know it is something to do with the Alarm (or is the Alarm ECU). But I cannot find this particular part online, nor can I find any model numbers on the actual box (or in it, I removed the screws). On one side the cable is not connected, if I connect it all the lights flash and the engine becomes immobilized. My remote keyfob works fine for lock/unlock, so i'm not sure what is going on. It has three other cables going into the other side. The only markings on the box say JT3KD1786-R. I attach pictures. I want to know if this is a standard stock part, can I replace it for another one that works properly? can I reset it?
Any help appreciated!
First photo shows the box
Second shows the cable that is not connected
Old Aug 30, 2006 | 02:52 AM
97DISCOIDAHO's Avatar
Default RE: Can anyone identify the box?
It looks to me like you're working on the drivers side (based on the brake pedal in the picture). I would have to guess this is an aftermarker alarm. Your key fob is working off the stock keyless entry system which I believe is in the dash behind the glove box. I'm pretty sure you're dealing with an aftermarket unit here.
Old Aug 30, 2006 | 09:18 AM
madas's Avatar
4wd High
Any idea how I might identify the manufacturer? that might allow me to get a manual and perform a reset / purchase the correct fob. The only code I can find is the one I posted previously.
Old Aug 30, 2006 | 11:41 AM
If the name of the company is not on the alarm it's probably a cheap off brand. You might be better of to just buy a whole new unit.
Old Aug 30, 2006 | 11:43 AM
madas's Avatar
4wd High
Thanks 97DISCOIDAHO.
Any idea is that wiring is standard? i.e. getting another unit would be plug and play.
Thanks
Graham
Old Aug 30, 2006 | 11:57 AM
I highly doubt it. It will probably need to be rewired. Good news is... you can find the wires pretty easy now that you have a harness already installed to show you the way.
DonRW2007
Jan 6, 2014 09:19 AM
Judgey
Jul 22, 2013 07:55 AM
ShadowMerchantBC
Sights N Sounds
Apr 19, 2011 10:27 PM
senna
Mar 16, 2011 03:51 PM
MGibbs
Sep 12, 2010 10:04 AM
