Can I install Harmon Kardon system in place of base stock system?
Hey guys - I was curious if I can easily install the HK audio system out of a Disco 2 into my "non-HK" Disco 2, or if there are a bunch of wiring issues that I'll run into. Does anyone know? The HK audio system sounds nice, but mine sucks. Thoughts?
I did this in my 2000 Disco. It had the Phillips stereo in the doors and i got the HK speakers to replace them, the only catch was the plugs were wired different. They had the same wiring harness but the wires were in the wrong spots so I took the small wiring harness apart that connects the speakers to the harness with a needle nose pliers and put the plugs in the right spots and put them back together and plugged them in and they work great. Yours should work also. Good luck!
OK, so if I already have the speakers, do I just swap all those out or do I swap out an amplifier as well? Long story short I have a Disco 2 parts truck that has the HK audio system, so I can access all the pieces....I just need to know what to replace. All the speakers should fit the same (other than the one comment about the wire connectors being different) but do I need to switch out an amplifier somewhere, and if so, are those connections the same? Thanks -
ajh
10-21-2007 06:59 PM
