Can I Run 31's on my 96 disco
Old Feb 21, 2007 | 11:13 PM
allstarbiker592's Avatar
Default Can I Run 31's on my 96 disco
Can i run 31 BFG A/T's on a stock 96 Disco???
Old Feb 22, 2007 | 10:35 AM
Landzu's Avatar
Default RE: Can I Run 31's on my 96 disco
You can run 245/75/16=31" if you trim the rear wheel area on the inside back bottom.
Old Feb 22, 2007 | 12:29 PM
You will need a 2" lift to run 31's.
Mike
Old Feb 22, 2007 | 06:23 PM
I am looking for the biggest that i can run without cutting any thing. What size would that be??
Old Feb 22, 2007 | 11:35 PM
Landzu's Avatar
The biggest is the stock.
The part that you trim is on the inside the lip not very much about 3/8th "
for about 4" from the bottom back, up.
Then about 2" from the bottom back at 45degs.
Then no lift needed. Mines is O.M.E. stock height.
You can not tell that anything has been cut from the outside.
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
DiscoBenjamin
Dec 8, 2010 11:18 PM
kschintz
Off Topic
Oct 4, 2007 12:09 PM
