Can the secondary air pump come on while driving?
Old May 28, 2019 | 02:57 PM
Brandon318's Avatar
Originally Posted by FlyingZebra34
Hold on everyone. That sounds like your electric fan coming on. This fan is for when you are idling or running the AC. If you stop and air isn't flowing through the radiator, the temp will climb. Once you hit about 210 degrees on the thermostat the electric fan will kick on. Your SAI will never turn on after the vehicle warms up. Only on start up.
That was what I first suspected when she called this morning, but I ruled it out when she said the highest temp the Ultragauge reported was 204. Also, I don't think the electric fan produces much in the way of audible sound. It's pretty quiet/ish.
Old May 28, 2019 | 02:59 PM
FlyingZebra34's Avatar
Depends on the fan speed. The fan can be triggered by a myriad of things. I'd have to plug is SSD to recall everything. Mine is very audible and sounds like a jet turbine when it comes on.
Old May 28, 2019 | 03:48 PM
Red5's Avatar
I agree it's designed to come on only during a cold startup. Nevertheless, mine does come on for 5-10 seconds occasionally, long after the engine's warmed up.
Old May 28, 2019 | 04:07 PM
Bignacio's Avatar
Mine only comes on for a couple of minutes from a cold start up. It has never kicked on while I've been driving.
Old May 28, 2019 | 04:32 PM
jastutte's Avatar
my money's on the SAI. on both my '04's the SAI has kicked on occasionally for only a few seconds long after startup.
and, yes. it does sound like a vacuum.
Old May 28, 2019 | 08:20 PM
CollieRover's Avatar
Auxiliary fan maybe?
Old May 29, 2019 | 05:12 PM
Discorama's Avatar
Have never heard my SAI pump coming on when driving, only at cold start.
Old May 29, 2019 | 08:39 PM
Best4x4's Avatar
My 04 doesn't do it, but I did have an 03 that would cycle on upon startup like normal, and then it "sometimes" would come on say when I exited a freeway and came to a stop on a cool morning.
ezragray
Nov 15, 2022 10:40 PM
Echoman
Nov 1, 2014 02:00 PM
LADEROUTE
Jan 12, 2014 02:35 PM
IDAHODISCO
Mar 14, 2009 08:22 PM
alamosweets
Sep 28, 2007 09:46 AM
