can a stuck or iffy caliper cause a 1591 rough road
Old Jun 24, 2018 | 08:53 PM
Richard Gallant's Avatar
Default can a stuck or iffy caliper cause a 1591 rough road
Ok got my amigos cleared up and the 1591 code showed up today ABS and TC lights. Indicated left rear on a NANOCOM- This is where I had a caliper issue.
The wheel sensor cable could be damaged causing odd ball readings.
I suspect the caliper is going, the brake pads are tapered top to bottom when I inspected them.
Hub could be iffy as well, although it seems ok no unusual movement.
Any suggestions ?
redwhitekat
Apr 23, 2020 04:38 PM
dmenchaca1966
Oct 18, 2018 10:14 AM
Jeff Blake
Apr 9, 2017 09:55 PM
adolfojbonilla
Apr 8, 2015 09:47 PM
stanigu
Apr 17, 2009 01:59 PM
