Can you replace the crucifix seals by dropping the oil pan and bearing retainer?
Old May 15, 2021 | 10:06 AM
Micmac's Avatar
Default Can you replace the crucifix seals by dropping the oil pan and bearing retainer?
Apologize I searched a bunch on this never came across an good answer. I’m still tracking down a leak. Leaking a bit worse after I did a oil sump gasket replacement attempt. Going to redo the the sump gasket and while I’m in there maybe replace the crucifix seals in hopes it’s not the rear main seal. I’ve dried the blue devil no luck.
if anyone can point me in the direction of a write up or rave manual page I’d appreciate it.
Old May 15, 2021 | 10:15 AM
RoverMasterTech's Avatar
Yes. You have to pull the starter for access to the cross bolts on the rear main cap.
Old May 15, 2021 | 10:32 AM
Micmac's Avatar
thank you RMT. I was reading you had a write up on this. I couldn’t locate it. Was there one?
Old May 15, 2021 | 05:58 PM
Yeah, somewhere. More bearing replacement specific, but it has the crusifix seals in there too.
Found it
https://landroverforums.com/forum/di...rite-up-48196/
Ignore all the bearing priming stuff, you don't need to, just a little grease on the bearing bottom
Old May 15, 2021 | 06:22 PM
JohnZo's Avatar
Does the same go for a D1? That is can the cross seals be replaced the same way?
Old May 15, 2021 | 09:16 PM
Extinct's Avatar
Yeahh
HuskerRover
Sep 29, 2021 07:57 PM
Brandon318
Jul 8, 2020 02:28 PM
s10lowrider1994
Aug 15, 2018 10:24 AM
austinlandroverbill
Feb 24, 2016 08:09 AM
Gizlby
Jan 20, 2011 12:20 AM
