This is new. Was redoing the caulking on the front sunroof. Somehow its opened in such a way that I cant get it closed. Had been leaking, so sunroof motor not working. Not even able to get it to budge with Allen wrench. How do I get it that last bit closed?
Try pulling the motor,you do not have to drop the headliner to do so, and see if you can turn the motor an allen key. If not disassemble the motor and just put the gear part back in. That should let you close it back up unless the track is jammed.
