Cant close front sunroof...
Old Apr 11, 2019 | 02:52 PM
jamestfl's Avatar
Default Cant close front sunroof...
This is new. Was redoing the caulking on the front sunroof. Somehow its opened in such a way that I cant get it closed. Had been leaking, so sunroof motor not working. Not even able to get it to budge with Allen wrench. How do I get it that last bit closed?
Old Apr 11, 2019 | 03:14 PM
Richard Gallant's Avatar
Try pulling the motor,you do not have to drop the headliner to do so, and see if you can turn the motor an allen key. If not disassemble the motor and just put the gear part back in. That should let you close it back up unless the track is jammed.
Brosnan
Jan 3, 2023 04:10 PM
Kras1967
Aug 10, 2014 11:59 PM
jpluncford21
Aug 8, 2011 07:46 AM
jrm123180
Mar 19, 2010 05:30 PM
alanroberts50
Nov 18, 2007 11:56 AM
