Can't Move Gear From Parking Position 97 Disco, Please Help
Old Nov 4, 2007 | 08:15 PM
felipenaves's Avatar
Default Can't Move Gear From Parking Position 97 Disco, Please Help
There a swicth from the pedal brake that is making a electric cut, and the gear is block , is imposible to move from parking, the mechanic that is working in the car, change the switch and now again happen and is block in neutral, can somedody please tell me what to do. I will apreciate thanks.
Old Nov 4, 2007 | 08:55 PM
Default RE: Can't Move Gear From Parking Position 97 Disco, Please Help
I am not sure what is happening but if you are having a problem shifting into drive and you have replaced the switch then there is a solenoid in the tranny that is causing the problem.
Old Nov 4, 2007 | 11:05 PM
Thanks Mike for the answer I would check that selenoide, the release for the key is affected to and the stop lights are not working.
Old Nov 5, 2007 | 06:49 AM
If your brake lights are not working then it has to be a bad brake light switch.
sson
Freelander
Jul 9, 2019 03:06 PM
Ghostsoldier
Apr 6, 2014 07:50 PM
jad568
Freelander
14
Apr 15, 2013 02:47 PM
Myarb10
Feb 20, 2011 09:07 AM
