Can't shift into D1
Old Jun 7, 2019 | 12:31 PM
originalpy's Avatar
Default Can't shift into D1
Hey guys - I will post a video soon - my 2002 D2 can shift out of park - reverse - D3 and 2 but not 1. I have to force the level harder than feels necessary and the light goes off from D2 but does illuminate for D1 and I cannot get the shifter into that drive mode.
Also - I feel like my transfer case is not all the way in 4high. It shifts fine into 4 low but when I bring it back it feels a little loose and a little higher like it hasn't quite got into gear. I have a high pitch whine at hwy speeds which I think is related to the transfer case as well and am looking for an 04 case to swap in.
Any advice?
Old Jun 7, 2019 | 01:04 PM
Richard Gallant's Avatar
Have you done the obvious :
Checked the fluid levels and condition of the fluids transfer case and transmission - check the RAVE for the procedure
Remove the bezel (the plastic thing on the console with the gear markers) make sure there is nothing blocking the shift lever travel
Take a look underneath and make sure there is no obvious damage
Old Jun 7, 2019 | 01:05 PM
originalpy's Avatar
QAll fluids have been changed in the last year - I removed shift bezel and inspected this morning - no obvious damage from below either.
EDIT: Scratch that I went out and double checked and there were more broken plastic bits still under the bezel. Got it and it shifts now. Woo-hoo!
Still have some t-case issues tho.
Old Jun 7, 2019 | 01:21 PM
Best4x4's Avatar
I’d personally loosen the 13mm nut that secures the PRND321 linkage and give it like 1-2mm more slack. Then test it’s operation.
Old Jun 7, 2019 | 01:41 PM
originalpy's Avatar
Doesn't look like it's in all the way
Old Jun 7, 2019 | 01:55 PM
Best4x4's Avatar
Yep broken bits will definitely mess things up! I’ve found plenty of change on D2’s in that spot
Kilby
Aug 15, 2019 05:45 PM
Old Bertha
May 6, 2019 04:11 PM
martin12
Dec 21, 2014 04:49 PM
discoandaboat
Oct 4, 2008 07:57 AM
bigugly82
Mar 19, 2008 12:45 PM
