Car wont start, Cant "Jump" either (help)
Old Apr 4, 2012 | 02:39 PM
hubie's Avatar
Default Car wont start, Cant "Jump" either (help)
Hubie the newbie here.
My Disco II's wiper blades stopped working awhile back (https://landroverforums.com/forum/di...d-swipe-45988/)
Then my car died and had to be jumped at the most inconvenient time (https://landroverforums.com/forum/di...new-one-48367/)
I had to go out of town for a week. Then I ordered a battery online from advanced auto parts, which includes a free install.
I called AAA to jump me, so I could go to the store and have it replaced. Guess what. Car wouldnt jump.
Horn blasted over and over. Blinkers went out. Dashboard flashed. Car would not start.
What's going on here? Should I just go to the auto parts store, buy the battery, then (pay) to have someone remove the old one and install it?
Hubie
PS - dont recommend I install it myself, it aint happening
Old Apr 4, 2012 | 02:46 PM
Draayer's Avatar
Default I had a similar problem
I just had a similar problem with the battery acting dead and couldn't be jumped, but I didn't have flashing light. My problem ended up being a ground wire was not connected. As was recommended to me, check your ground wires, there are a few of them. Good luck
Old Apr 4, 2012 | 02:51 PM
Eaglerover22's Avatar
Sounds like something is up with your alarm. Did you unlock/lock/unlock the doors? Is your transmission in park? There's a bunch of old posts regarding people's alarms/kill switches. Also, you can install the battery yourself. I think its a 13mm socket to loosen the connections. Takes less than 30 seconds. Then call a lead scrapper on Craigslist to come take the old one away for you. On a side note, I removed my battery bracket and replaced it with a nylon strap. Is there any reason the battery needs to be firmly bolted to the tray, or is LR just trying to be a pain in the neck?
Old Apr 4, 2012 | 02:54 PM
Well, I guess I ingored the post script.
Old Apr 4, 2012 | 04:41 PM
hubie's Avatar
how do i disable the horn?
Old Apr 4, 2012 | 05:09 PM
Jared9220's Avatar
Put the key in the drivers door and lock it then hold it on unlock for a few seconds. That should fix the horn.
Old Apr 5, 2012 | 07:12 AM
NoBama316's Avatar
I'd sell it and buy something else if you can't install a battery.
TRIARII
Jul 12, 2014 10:01 PM
Disco Mike
Jun 21, 2012 09:32 AM
Disco Mike
May 27, 2011 09:29 AM
rjennings
Aug 29, 2008 02:34 PM
bobbydave
Dec 8, 2007 12:49 PM
