Catalytic converter touching the driveshaft?
Hello, I own a 2000 Land Rover Discovery Series 2. The right hand catalytic converter and driveshaft seem to be in contact and rubbing with each other. I have tried replacing the engine mounts and they are still in contact with each other. Any suggestions on what may be causing the problem?
@pbreche2000 I would disagree the exhaust is either bent from road damage or installed incorrectly. Either way you are doing damage to the cat, drive shaft and possibly the drive train.
You just need to get it fixed, then everything else checked. Driveshaft balance should be checked too
