CC vacuum hose.
CC vacuum hose.
My cruise control does not work. After searching the forum I found out that 99% of the time its just the vacuum hose.
Looked under the hood. Lots of hoses and tubes Where do I start? I basically know the major hoses and engine components. But the CC vacuum hoses are kinda tricky to locate.
LR shops here will surely charge me overpriced labor costs for a simple problem (or so it seems)
Help!
Help!
RE: CC vacuum hose.
I had this problem a while back, and there is more info in the archives, I'm sure. There is a vacuum hose that goes from the brake pedal switch in the cabin, through the firewall to a 'tee' fitting right by the brake servo. One end of the 'tee' goes to the diaphram that controls the throttle, and the other end goes up front behind the left headlight under the jack to the vacuum pump. They usually break or fall off at the 'tee' fitting. If you find the 'tee' fitting, just follow all three hoses until they disappear :^).
