CC vacuum hose.
Old Nov 24, 2008 | 09:40 AM
DiscoRom's Avatar
Default CC vacuum hose.
My cruise control does not work. After searching the forum I found out that 99% of the time its just the vacuum hose.
Looked under the hood. Lots of hoses and tubes Where do I start? I basically know the major hoses and engine components. But the CC vacuum hoses are kinda tricky to locate.
LR shops here will surely charge me overpriced labor costs for a simple problem (or so it seems)
Help!
Old Nov 24, 2008 | 10:12 AM
DiscoJag's Avatar
Default RE: CC vacuum hose.
I had this problem a while back, and there is more info in the archives, I'm sure. There is a vacuum hose that goes from the brake pedal switch in the cabin, through the firewall to a 'tee' fitting right by the brake servo. One end of the 'tee' goes to the diaphram that controls the throttle, and the other end goes up front behind the left headlight under the jack to the vacuum pump. They usually break or fall off at the 'tee' fitting. If you find the 'tee' fitting, just follow all three hoses until they disappear :^).
Old Nov 24, 2008 | 11:36 AM
DiscoRom's Avatar
Got it thanks Disco Jag.
Old Mar 11, 2021 | 03:54 PM
swissarmychainsaw's Avatar
Anyone know what size the vacuum hoses are for the CC?
Old Mar 13, 2021 | 09:52 AM
mln01's Avatar
5/16 inside diameter
Old Mar 13, 2021 | 11:35 AM
JUKE179r's Avatar
That’s about 8mm for us metric people.
Toran
Jan 7, 2020 05:26 PM
Raysteve27
Jul 22, 2017 10:04 AM
Chrisw7562
Jan 16, 2017 10:24 AM
philwarner
Mar 16, 2016 08:00 AM
AZlandy
Sep 4, 2012 09:38 AM
