CD changer to ipod swap
Old Aug 25, 2013 | 07:58 PM
mln01's Avatar
Grom Audio Bluetooth. Forget the cables.
http://www.gromaudio.com/store/bt3_a...e_adapter.html
Old Aug 25, 2013 | 09:24 PM
willypilgrim's Avatar
ROVER LANDROVER 99-05 AUX-IN Android iPod Bluetooth Adapter
Do you have this installed and currently in use? Does it work well? This looks like exactly what I was hoping to get for our 03 discovery we just bought.
Old Aug 25, 2013 | 09:29 PM
mln01's Avatar
Yes. For over a year. And we love it.
Old Aug 25, 2013 | 09:41 PM
Fallstaff's Avatar
I just tapped into the wires for the CD changer and put a 1/8th pin input on the passenger side seat control panel. Pretty straight forward once I figured out which wires were which. You do have to cut both grounds and splice them together or the cd still plays through (much to my surprise).
I still have to power the disc player and leave a single disk in it to get it to work (someone smarter than me could find a way to do without this I'm sure). Means it stops for 20 seconds every 45 minutes when the disc ends, but other than that it's just perfect.
And I then use a bluetooth to Audio when I want bluetooth.
Eventually I want to put a second plug inside the storage compartment with a USB and a couple of 12 volt plugs so I can hide the whole bluetooth arrangement away.
Bought some 8 pole switches so I could turn the CD back on, but then realized I don't own any CDs so didn't bother in the end.
Old Aug 26, 2013 | 08:32 PM
Sweet, good to hear. Did you install behind the radio or were you able to connect to the cd changer under the seat (if you had one)? I installed an iphone adapter in multiple cars with cd change inputs so I'm sure i can handle the install but under the seat seems much easier if I can. Thanks for the info by the way.
Now i just need to figure out my stereo code... No card in the manual like my vw had. Going to have to call the previous owner and see if they have it available.
Old Nov 22, 2013 | 03:22 PM
utdiscoII's Avatar
Falstaff,
I'd like to replicate your project. Do you have a pick of the splice? How did you figure out which wires were which? And did you have a problem with the stereo code? Thanks up front.
Old Nov 22, 2013 | 11:30 PM
Fallstaff's Avatar
Originally Posted by utdiscoII
Falstaff,
I can't remember which wires, but with the rave it was pretty basic. I think everything is hidden under tape now, but I'll try and remember to look during the three minutes of daylight we currently get around here.
CD player is fine, it just thinks it's playing CDs. Means there's a two second break in the sound every time the disk comes to an end (keep meaning to put the longest CD I have in there).
bennyb43
Dec 11, 2013 08:17 AM
WaltNYC
Mar 10, 2010 11:56 AM
johnnyz
Off Topic
Sep 27, 2007 09:02 AM
daisybcb
Off Topic
Aug 4, 2007 08:46 AM
pvalianatos
Apr 6, 2005 06:49 PM
