CD changer replacement
Old Jun 10, 2010 | 09:33 PM
lordmorpheus's Avatar
Scott, have you tried cold booting it? Every now and then I get the dreaded "no disc" error. What seems to be happening on mine: insert magizine, arm pulls out the tray, but not far enough to detect anything, moves to the next tray, does the same thing, through all 6 trays, then says "no disc". Ejecting and reinstalling the magazine does no good.
What I have found works, *99% of the time on mine, is to unplug the changer from the harness under the passenger seat, and let it remain without power for a minute or two, then reconnect and try again. Most of the time it works on the first try. Sometimes I have had to do that with magazine out, reconnect the power and reinstall the magazine, other times I have been able to leave the magazine in the changer while cold booting it. It depends on how she is feeling that day.
*the 1% when it didn't work was because a tray was out of the magazine and jammed in the changer. I couldn't eject, change discs, or anything. I had to remove the changer, disassemble, manually remove the tray, figure out how everything inside the changer works, clean, and reassemble it.
devildollnyc
Jun 21, 2011 03:33 PM
jiminoc
Audio/Visual Electronics
May 19, 2008 11:11 AM
igenov
Feb 4, 2006 06:54 PM
khtemple
May 18, 2005 11:05 AM
rahala
Jan 6, 2005 03:59 PM
