CD player problem
I recently spent a good deal of time cleaning up my old truck, including the replacement of an after-market radio with the original OEM setup. I was surprised that it worked as well as it did as soon as it was put into the dashboard and pleased with quality of the sound from the old set. There's no Bluetooth or navigation of course, but my daily driver has enough of those bells and whistles to keep me happy.
After a couple of weeks, however, the CD changer suddenly stopped working. Loaded with six discs, it worked well through four of them, then failed to load the next available. Now all it get from the set is "NO DISC", regardless of how many discs might be the caddy. There's just no response.
When the disc caddy is inserted it sounds like it means business, but still "NO DISC".
If anyone out there has an idea of what might cause this, I'd love to hear it. Any suggestion of a fix will be greatly appreciated.
As always, any assistance will be appreciated.
Mine does this fairly often. Ejecting the caddy and reinserting it would fix it for a while, but it would always come back.
I ended up picking up a GROM unit so I could connect a hard-drive based media player, which works fine. You do lose the ability to play CDs though.
Time to fish a GROM wire through there.
This is a simple fix usually. Remove the top cover of the CD changer. You will see the arm that grabs the CD from the magazine. It's usually got some grease on it & over time the grease attracts dust/dirt/lint and it prevents it from moving properly back & forth. If it doesn't fully rack back & forth it will say No CD. I suggest cleaning it, and then lightly lubing it. Once it can move freely you should be good to go.
SteveP143
Dec 24, 2012 07:47 PM
discoveryrover1995
Oct 30, 2009 02:02 PM
