CD stuck in the player under the passenger front seat
Is the disc stuck in the magazine or in the player?
If the magazine is stuck, push in on the mag while pressing the eject button. Should pop out.
If disc is stuck, remove all other discs from the magazine. Turn on player and let it run the testing cycle. Might kick it out. Try first thing again without any discs in player.
Had that a bunch of times. Takes patience and some times an extra pair of hands to turn radio on.
OffroadFrance (09-15-2017)
I had a similar problem a few weeks ago when the player wouldn't load a CD. At the suggestion of someone here, I took out the passenger seat and disconnected and removed the player. Taking off the top cover, I found a few years of crud had stuck the disc-change mechanism. A little cleanup and reinstallation solved the problem.
97RR
07-20-2010 01:31 PM
