Cdl
Old Mar 31, 2016 | 09:09 PM
Micko's Avatar
Default Cdl
Hi Guys
Is there a neutral position between the on/off position of the CDL?
When I rotate it with a 10 mm wrench it feels like 3 positions.
When I connect up the shifter it seems like I don't have enough travel to disengage the CDL.
I havnt swapped it into the truck yet so no light.
Thanks
Micko
Old Mar 31, 2016 | 09:23 PM
Bom2oo2's Avatar
There is a neutral position between high & low,,, but no neutral position between CDL, it's either locked or not, can't set it half way, what kind of linkage are you going to use for it, one from a 04 will be very straight forward instal,,
If using a D1 linkage, you have to adjust it to work properly,,
Old Mar 31, 2016 | 09:35 PM
number9's Avatar
From manual per CDL cable adj., may help.
CAUTION: Should the lever move past the
detent, allow it to move back into the non
differential lock detent position before
adjusting the cable.
Old Apr 1, 2016 | 05:33 AM
Micko's Avatar
Its an 04 linkage that came with the 04 case. I had it in my mind that there was a neutral there for some reason & thought i didn't have enough travel to disengage.
Thanks
Guys
Old Apr 1, 2016 | 11:59 AM
Big Jim Swade's Avatar
I just installed an 04 shifter in mine back in January. I didn't have to adjust anything. Just make sure the opening on the mounting plate clears the shift lever as it moves from side to side in both low range and high range.
Old Apr 1, 2016 | 09:14 PM
Micko's Avatar
Hi Big Jim
Did you remove the solenoid on the linkage for the hi/lo,and if you diddn't where did you connect that wire too?
Thanks
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
lipadj46
Feb 11, 2010 07:45 AM
disco12
May 12, 2006 12:03 PM
kcabpilot
Apr 3, 2006 02:21 PM
