Cdl done in under an hour so what do I do next
Old Apr 16, 2011 | 10:53 PM
Sunny side auto's Avatar
Default Cdl done in under an hour so what do I do next
Cdl is done winch and bumper are done. Cup holder done lift kit done head gaskets done . I'm thinking air lockers and snorkel ? What would u do?
Old Apr 17, 2011 | 05:53 AM
Bundu's Avatar
Banned
Go wheeling
Cup holder ?????
Old Apr 17, 2011 | 07:23 AM
mln01's Avatar
So what method did you use to enable the CDL? DI shifter? Something else?
Old Apr 17, 2011 | 08:35 AM
hilltoppersx's Avatar
rebuild the front drive shaft with greasable u joints, transmission and TC fluid swaps, and take it out wheeling. Where are you Queens?
Old Apr 17, 2011 | 10:06 AM
I used the D1 shifted and modded it by cutting the end off both the D1shifterr and the factory shifted so that the small roll pin would still work and I could use the factor cable end. I bought the shifter off Craigslist for 25 bucks. And found a like new drive shaft for 45 bucks at LkQ in Portland Oregon shaft has grease able u joints .
Old Apr 17, 2011 | 03:05 PM
NiteTrain's Avatar
if you can do the D1 CDL shifter in under an hour you should be able to install new 8mm wires in 15 mins..ready..set..go!
Old Apr 17, 2011 | 06:53 PM
ringerso's Avatar
Any chance of seeing some pix of your D1 install? I'd like to see what you mod'ed up. Very impressed that you did that in under an hour...it took more longer than that to get the damn shift **** off...LOL!
filbs
Apr 6, 2012 02:04 PM
honda50r
Apr 24, 2011 09:37 PM
RROJ
Jul 2, 2010 11:05 AM
RROJ
Jun 9, 2010 05:45 PM
Tamango
Nov 29, 2007 03:41 PM
