CDL just installed, one question.
Old Oct 17, 2010 | 10:41 PM
jackstraw's Avatar
Default CDL just installed, one question.
I finally got around to getting my DI CDL linkage into my 2000 DII. It actually went fairly well, the trickiest part was getting the bend correct in the hi/lo connecting rod. Overall, the whole thing works great, nice and smooth.
The one problem I have is that when I shift into lo it doesn't seem to engage as much as it used to. I have to push up on the shifter pretty hard (just at the very up position) to get the transfer case to stay in lo.
My question is, will the solenoid in the transfer case ensure that it will not slip out of lo once the transmission is in anything other than neutral?
Also, is the dash light and beep indicating the transfer case is in neutral a safe indicator (once it's off) that everything is engaged properly?
Thanks.
Old Oct 18, 2010 | 08:34 AM
hilltoppersx's Avatar
i had the same experience where the throw on the D1 linkage isnt as much as it was on teh D2 linkage. For that reason i am switching back to the D2 linkage and will use a different trick to engage the CDL either cutting an access plate or a flat bar that will be affixed to the nipple that i can just reach under the truck and push forward or back. yes once the dash light and beep is off you are fully engaged.
Old Oct 18, 2010 | 08:56 AM
No there is no solenoid to keep the t-case from slipping back into neutral, thats why there is a buzzer.
If it is buzzing you are not fully engaged.
Old Oct 18, 2010 | 10:05 AM
jackstraw's Avatar
Bummer. I thought there was a solenoid to keep it from slipping out of gear. Is there anything to keep it in other than just the linkage? It seems there would be something to lock it in so you couldn't accidentally shift out of lo or hi when in drive. If not, I guess I have more work to do.
Hilltoppersx, please let me know what you end up doing. I may need some info to do the same if I can't get this DI working linkage right.
Old Oct 18, 2010 | 10:30 AM
The solenoid in the t/case is to make sure you don't shift into low range while the tranny is in drive.
Old Oct 18, 2010 | 10:48 AM
jackstraw's Avatar
Oh ok, Thanks Mike. I'm assuming it just the detent in there that keeps it in gear then?
Old Oct 18, 2010 | 11:43 AM
From what I understand there is a spring that holds it into CDL, so as long as you are fully engaged it will in no way slip out.
However if it is NOT fully engaged then yes it can slip out of gear.
turbodave
Mar 29, 2019 07:22 AM
lipadj46
Feb 11, 2010 07:45 AM
Camdisco24
Dec 31, 2009 07:31 AM
jycsalas
May 4, 2009 11:43 AM
rmally
Apr 22, 2008 12:26 AM
