CDL kit Discussion [Center Locking Differential]
Old May 24, 2013 | 09:38 AM
  #21
Dean's Avatar
FYI... Looks well made. Not my choice though.
CDL Land Rover Discovery 2 D2 Central Difflock Diff Lock Shifter | eBay
Old May 24, 2013 | 09:40 AM
  #22
Paul Grant's Avatar
Originally Posted by captain203
I am picking up the shifter *** from a D1. what part are you referring to by shift plate?
It's also know as the hi/lo cover. It's held in place by 6 bolts. The arm coming out of it on the DII is at 90 degrees. This leaves a gap between the linkage TO the hi lo arm. On the DI's the arm is canted making up for the gap. Thus, no need to bend (and possibly break the rod on the linkage to the hi/lo arm coming out of the cover. It makes for an easier and cleaner installation.
Old May 24, 2013 | 09:46 AM
  #23
Paul Grant's Avatar
Originally Posted by Dean
That's a little over $400 US with shipping. Not really all that cheap. Isn't the Ashcroft right around the same price? I think their website has the shifter listed for just a few more pounds.
Old May 24, 2013 | 10:36 AM
  #24
captain203's Avatar
Originally Posted by Disco Mike
The Hi/Lo shift plate is the plate that has the verticle arm that the Hi/Lo shift arm hooks to. It has the proper angle on the shift arm so it bolts right up.
Ok so the large bracket that holds rhe shifter and bolts to the top of the case? that is coming with the the shifter and rods.
Old May 24, 2013 | 10:39 AM
  #25
Paul Grant's Avatar
See if this helps in understanding what Mike and I are talking about.
DI CDL - LAND ROVER CLUB V.I.
Old May 25, 2013 | 09:31 PM
  #26
acamato's Avatar
For an 04 cdl shift assembly, try car-parts.com. I found one from a junk yard in TX for $118 shipped. I didn't get the lever that goes from the nipple to the cable. I ended up getting one from Ashcroft. It was around $40 shipped.
Old May 26, 2013 | 11:07 AM
  #27
captain203's Avatar
Yep makes sense now. Thanks for the info. Got the whole set up including the hi/low selecter housing with the bent arm.
Old May 26, 2013 | 02:56 PM
  #28
SWAINROVER's Avatar
Default wrench
what mm wrench are u useing to turn cdl
Old May 26, 2013 | 03:26 PM
  #29
bballjames's Avatar
It's a 10mm
Old May 26, 2013 | 07:04 PM
  #30
SWAINROVER's Avatar
Default cdl
would it hurt to run with cdl lock all the time ?
