CDL Ordered
Old Jan 9, 2012 | 07:08 PM
  #21
bosshogt's Avatar
Its a son of a B. I just did it about 3 weeks ago, using a D1 shifter. Call me if you get stuck. My front output would not come forward with the output(diff gears) housing removed. Mine all went back together fine. I ended up having to remove the rear output, Emergency drum brake, rear propshaft and housing. Once I removed that The front slipped past those gears.
Call me if you need help
317-201-2847 Anytime after 12noon
Dave Kimsey
Old Jan 12, 2012 | 07:38 PM
  #22
Kalel's Avatar
Thanks, I will. I need to get the old one out. We worked on it for 5 hours and with all the rust it is a pain. I broke the 4 rear cross member bolts on the drivers side, I plan to wield the thing back in, and did not have to remove the front cross member. I hope to get it back together Saturday and I still need to get the Amigos to go off.
Old Jan 14, 2012 | 10:23 PM
  #23
Kalel's Avatar
We got the new one in, but I did not remove the old gear-set. I could not understand why the instructions said I had to remove them and there was no details. Hope to get the shifter hooked up tomorrow and see what it can do.
Old Jan 15, 2012 | 10:15 PM
  #24
Kalel's Avatar
Done the install and everything seems to be working, except a exhaust leak and another issue. I need some help with this one. When I put it in 4lo the little light on the dash that has gears with a line through them comes on and it beeps. The Disco still drives, but the beeping and the light is an issue.
Old Jan 16, 2012 | 04:23 PM
  #25
Kalel's Avatar
Got the Exhaust leak fixed, $30.00, and now I need to fix the Hi/Lo switch. I think that is the problem, unless anyone here has a different theory. I also must do the ABS option B.
Old Jan 17, 2012 | 09:34 AM
  #26
grandkodiak's Avatar
Its just sensing that the xfer box is fully engage, like being half in gear that might pop out in a manual shift car as far as i understand that light. sometimes it can be tricky to change fully from lo/high... are you changing at rest or while at slow speed? mines far easier at slow speed but takes some getting used to.
Old Jan 18, 2012 | 12:37 AM
  #27
Kalel's Avatar
It worked itself out. Thanks all. Now on to the ABS option B.
turbodave
Mar 29, 2019 07:22 AM
Camdisco24
ROAMING WITH FRIENDS
Sep 25, 2009 12:24 PM
kaczman
Feb 4, 2007 04:22 AM
yayo
Jan 17, 2007 07:50 PM
Disco Alan
Jul 14, 2006 01:28 PM
