CDL shifter on the cheap
Old Aug 2, 2015 | 01:35 AM
eitydeuce's Avatar
Default CDL shifter on the cheap
Just finished putting in my cdl shifter in today. I found a 96 disco in the wrecking yard and pulled out the transfer case shifter, linkage and hardware. I also was able to use the housing off the 96 case that has the proper offset for the linkage so no bending was required. While I was at it I replaced the stuck solenoid and modified the detect switches due to intermittent continuity. All in all it cost me about 40$ for the shifter with all linkage and housing and few hours in the driveway. Works great no modification needed and best of all not much out of pocket. Looking forward to hitting some trails now!
Old Aug 2, 2015 | 08:28 AM
Andy2Rover's Avatar
Yup, great, cheap mod. Took me more than a few hours in the driveway though. More like a few day. No room to work in there, but at least the work is from above, not below the truck
Old Aug 2, 2015 | 08:50 AM
Charlie_V's Avatar
I wish I had a rover boneyard close to me. Congrats on your mod.
Old Aug 2, 2015 | 10:21 AM
Great mod, and for those about to do this, make sure you also get the Hi/Lo shift plate as he did so you don't have to bend and or modify the linkage.
Old Aug 2, 2015 | 02:06 PM
eitydeuce's Avatar
I'm going to do a write up on modifying the detect switch as its easy and does not require any parts, only a dremel tool and a carbide bit is needed. It sure beats paying over $100 at the dealership and it's guaranteed to work.
Old Aug 2, 2015 | 02:08 PM
eitydeuce's Avatar
I also pulled an extra cdl set up so if anyone is interested send me a message
turbodave
Mar 29, 2019 07:22 AM
Chris528
May 7, 2010 08:37 PM
Jull
Oct 29, 2008 10:42 AM
Wanix
Oct 16, 2008 05:39 PM
rcshauger
Oct 3, 2008 05:36 PM
