CDL/TC question
Old Oct 8, 2011 | 02:33 AM
elrocha69's Avatar
Default CDL/TC question
I am planning on upgrading my 02 with a CDL and I was wondering if the Traction control is disabled when the CDL is engaged. I think I heard something about the TC not working on vehicles equipped with the CDL and TC. I could be wrong though. I would think the TC and CDL together would be the next best thing to a Diff lock. I don't want to lose the TC when I engage the CDL, because without the TC your back to a regular 4x4 that will spin one front tire and one back tire when the terrain gets slick and muddy. That is one reason I love the TC, especially crossing ditches and rock crawling. Other people that try to follow me through ditches end up spinning one front and one back tire and I end up having to pull them out unless they have a locker. Also, what transfer cases will fit my 02 Disco II? I know of a couple rovers in a local salvage yard but they are not Disco II's. One is a 95 Range Rover locally the other is a 2001 Disco II but not sure if it has the lever for the CDL as it is almost 2 hrs away. I would be ecstatic if the Range Rover T/C would fit. Thanks for the help.
Old Oct 8, 2011 | 11:02 AM
If you want any help with the CDL issue, send me your number and I'll walk you thru your options.
Old Oct 8, 2011 | 11:10 AM
kenk's Avatar
Unless someone has converted it, the '95 RRC will not have a CDL. The '01 may, as roughly the first half of '01(and all '99 & '00 D2's) had the cdl, but the shifter was not set up to engage it.
My '04 does not disable TC or HDC when the CDL is engaged
BTW, if you've never seen this site, check it out:
http://www.car-part.com/cgi-bin/sear...erPage=1&iKey=
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
lipadj46
Feb 11, 2010 07:45 AM
Willie 00D2
Sep 11, 2008 02:05 AM
Disco Alan
Jul 11, 2006 06:33 PM
