CEL Codes
Old Jun 6, 2010 | 11:41 AM
jpperry's Avatar
Default CEL Codes
Check engine came on this morning when my wife was driving; first she said it was blinking then turned solid. Read the codes and got P0305 and P1319. I know this is a misfire in cylinder 5 and a misfire caused by low fuel, the fuel light was on. Cleared the codes, drove to gas station, filled up and drove back. Codes did not come back on. Haven't had this happend before when the fuel level was low. It is an '01 with 115k on it. Any thoughts on what may be the root cause?
Thanks.
Old Jun 6, 2010 | 11:45 AM
Tell you wife to not go under a 1/4 tank of gas or you will be replacing that fuel pump sooner then later cause it will over heat with little or no gas to cool it.
Old Jun 6, 2010 | 04:47 PM
lordmorpheus's Avatar
AMEN on that Mike, I try to refill at 1/2. The only time I go below is when I need a carwash, and try to save a few bucks by buying a carwash and getting $.10 less a gallon, then I let it get to 1/8 tank or so.
Old Jun 7, 2010 | 09:03 AM
hilltoppersx's Avatar
yeah don't let it get below 1/4 tank
Soccer Dad
Jan 27, 2011 09:49 AM
petedisco96
Nov 9, 2009 02:08 PM
97DiscoKid
May 30, 2007 04:07 AM
Jwilk
Nov 4, 2006 01:04 PM
Corsair33
Sep 1, 2006 12:13 PM
