Returning cel codes P0300 p1316
Old Nov 8, 2009 | 06:03 PM
petedisco96's Avatar
Default Returning cel codes P0300 p1316
The other day I replaced my wires and this light came back, runs fine except when I hit the brakes and slow way down I get alittle surge or residual power from the engine. Also power steering is hard when stopped in both dirrections rolling its ok Ive been changing the fluid but I guess it wont help. Anyone know about these two codes? thanks
96 discovery automatic 142,000 miles
Old Nov 8, 2009 | 07:08 PM
lipadj46's Avatar
They are misfire codes. Check your connections something is not right.
Old Nov 9, 2009 | 11:25 AM
When did you last change your p/s fluid, how about your belt and tensioner, are they still tight?
Old Nov 9, 2009 | 01:35 PM
Question
The main thing is when I slow down to turn the check engine comes on with the 2 misfire codes. like a power surge but not on excelleration.
I shortened the hose on the pump because of leaking and have turkey basted it several times now the belt is good and pump is quiet but kinda weak.
Old Nov 9, 2009 | 01:38 PM
If the pump isn't dead yet, and it's quiet, throw a can of Lucas p/s additive in and see if it will free up the valving, possible cheap fix before going and spending the big bucks.
Old Nov 9, 2009 | 02:08 PM
Any idea what the missfires on braking could be caused by?
Ladderman
Nov 4, 2013 07:19 PM
rynus311
Aug 12, 2013 11:34 AM
dsmeddy
Apr 10, 2013 11:35 AM
keoni004
Nov 4, 2012 05:06 PM
zer0Point
Apr 22, 2012 06:37 PM
