CEL & codes
Old Aug 21, 2012 | 06:13 AM
drowssap's Avatar
Default CEL & codes
I guess it was bound to happpen eventually, any on my ride in this morning my cel came on with the following codes:
p0327
p0420
p0430
p0153
p0133
p0170
all are new the memory was cleared last week or so.
I dont have a rave with me can someone help me out with these codes
Old Aug 21, 2012 | 07:07 AM
p0327 Knock sensor 1 circuit low input (bank 1 or single sensor)
LH bank signal less than threshold determined from ECM model above 2200 rev/min
p0420 Catalyst efficiency deteriorated - LH bank (NAS and EU-3 only)
p0430 Catalyst efficiency deteriorated - RH bank (NAS and EU-3 only)
p0153 O2 sensor circuit slow response (bank 2, sensor 1)
Front sensor aged - period time too long/too short RH bank
p0133 O2 sensor circuit slow response (bank 1, sensor1)
Front sensor aged - period time too long/too short LH
bank
p0170 --- sure this wasn't P1170?
BTW, if no RAVE on USB drive in glove box, see my signature for an on-line link that lets you go to individual sections on line, no need to download whole enchilada.
Old Aug 21, 2012 | 07:12 AM
drowssap's Avatar
so it looks like a knock sensor and I assume it would be smart to replace all four 02's
Old Aug 21, 2012 | 07:13 AM
When was that engine last tuned along with new 8mm silicone wires and have you ever blown a head gasket?
Old Aug 21, 2012 | 07:19 AM
drowssap's Avatar
Mike,
everything was replaced last feb. HG, Plugs, Wire, WP, TC, Belts, hoses etc. The head gasket were replaced before they blew, i stripped it down to a short block and replaced everything as i built it back up.
Old Aug 21, 2012 | 07:21 AM
drowssap's Avatar
Mike,
I did not go with 8mm wire becaue of the shippping delay I used AB 7 mm wire. But they are only 18 months old.
Old Aug 21, 2012 | 07:25 AM
Well, it is time for parts, but first go check your charging system make sure it is between 13.6 and 14.4 volts cause if low, it can cause the ECU to throw bad codes.
If the charging system is good then I would would start with a knock sensor, 2 new front 02's and plan on a couple replacement cats if they don't clean up with a can of 44K.
Old Aug 21, 2012 | 07:47 AM
drowssap's Avatar
mike, the charging system is fine Im getting 13.8 at ECM, you kind of lost me on the can of 44K. IS THAT LIKE SEAFOAM OR SOMETHING
Old Aug 21, 2012 | 08:08 AM
drowssap's Avatar
FOUND IT THANKS BG Findashop - Search for an authorized BG service center near you!
Old Aug 21, 2012 | 09:00 AM
44K is by far the best fuel additive on the market, been around for over 20 years and as part of cleaning the carbon from the engine it will work it's way into the cats and possibly clean them enough to free up their codes.
Jared9220
Apr 10, 2026 11:58 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Jwilk
Nov 4, 2006 01:04 PM
Corsair33
Sep 1, 2006 12:13 PM
