CEL flashing, rough running.
Old Jan 25, 2010 | 07:23 PM
Fobra's Avatar
7th Gear
E1300, P0306, P031 ... the car is running alright now, but still has the CEL lit.
Old Jan 25, 2010 | 07:49 PM
lipadj46's Avatar
I assume you meant P0301, if you you have a misfire on cylinder 6 and 1. Get some 8mm magnecors from Apex Performance or if you don't want to spend $100 order 8mm kingsborne wires and change out the plugs also (use your plugs of choice singele platinum, double, iridium even plain champion coppers work great in these engines). See the sticky for how to DIY the wires.
Edit: 1 and 6 are on the same coil so if new plugs and wires do not fix it you may have a bad coil.
Old Jan 25, 2010 | 07:54 PM
Fobra's Avatar
7th Gear
awesome, thanks guys, you have been a great help.
dillhole
Feb 20, 2020 02:30 PM
mirrajumper
Nov 22, 2012 11:08 AM
tsuami1
Jan 26, 2011 10:21 AM
JPC97DiscoSD
Apr 24, 2008 09:13 AM
gsgtsg
Jan 23, 2008 01:46 PM
