Cen-Tech OBDII code reader problems
Old May 9, 2009 | 08:23 PM
Photojoe4's Avatar
8th Gear
Default Cen-Tech OBDII code reader problems
The ABS light and Service Engine lights have been on in my 98 Disco, so I picked up a fairly cheap OBDII code reader from harbor freight today in the hopes of finding out what might be causing it. Followed the included instructions and it comes back with no error codes. So, I hit "erase codes" to reset the lights, and they still come on when I start the engine. Any ideas? It's running/driving fine, but those lights are really buggin me.
Regards,
Joe Martin
Old May 9, 2009 | 09:00 PM
sforb's Avatar
That code reader wont read abs codes, a abs amigo will
Old May 9, 2009 | 09:20 PM
greg409's Avatar
Regards,
Joe Martin
The abs can be read & cleared by you through ecu under driver's seat (has diagnostic led)
The service engine (red) light can be reset by you behind pass side kick panel (there's a reset hole in relay) mileage triggered
neither will trigger normal or obd2 codes
luck,greg
Old May 11, 2009 | 09:55 PM
Photojoe4's Avatar
8th Gear
I can't seem to find the diagnostic led under the drivers seat. Any pictures of what I should be looking for?
Old May 14, 2009 | 04:55 PM
pilsner's Avatar
the diagnostic connector is under the drivers side DASH. just under the steeringwheel and slightly to the right of center. good luck
Old May 14, 2009 | 05:47 PM
greg409's Avatar
If you snoop around, you'll find the procedure to read & reset your ABS codes.
I'm sorry, the abs ECU is behind the glovebox (not under driver's seat), but the led to read & reset ABS codes is under the pass seat
Try this (LRFAQ.org)
I just read this site today.
Old May 14, 2009 | 09:03 PM
Photojoe4's Avatar
8th Gear
Thanks guys. The Service Engine light actually just went off on it's own. I'll see if I can read the ABS codes this weekend.
Regards,
Joe Martin
Old Jun 3, 2012 | 12:34 AM
thegoat's Avatar
I'm looking behind the passenger side kick panel for said relay switch for red service engine light. Any clues to where said relay us down here, I'm clueless. Thx in advance.
Old Jun 3, 2012 | 12:41 AM
thegoat's Avatar
Disregard, getting answered in different thread, sorry.
Externet
Jul 1, 2019 10:21 PM
WaltNYC
May 28, 2014 12:34 PM
sayeedA
Mar 9, 2014 09:27 PM
Chrisinhouston
Feb 10, 2008 09:22 AM
NCdiscoII
Jul 14, 2006 06:21 AM
