Center console trim
Center console trim
So my 04 has the wood trim plate in the center console which is cracked and just generally fake and tacky looking. Ive seen black trim in this area in Google pics but when I search for replacement pieces all I find is the two piece rubber mats. Are the rubber mats a direct replacement for the wood trim, or do they go over the top? I was assuming there was just a single piece of black trim that is identical in shape to the wood piece.
If you have the wood it's likely that yours is what's called a skateboard.
the panel is contoured up into the switch plate.
Your t case case shifter boot plastic base has extended tabs to accomodate the thickness of the skateboard.
If you remove, you need the rubber mat, new shifter boot plastic trim, and switch panel.
Ok awesome. Thanks for the info guys.
BTW, I just found this and kindof like it. Pretty steap for a trim piece but it looks pretty slick. I'm gonna see if they'll throw in their shifter and ebrake boots if I buy the pannel.
http://www.blacklistedengineering.com/blacklisted-engineering-products/d2-center-console
KingKoopa - found the rubber console mat this weekend and I have your address - I'll send it out USPS tomorrow.
Also, installed this over the weekend. Bit of a pain, but after all is said and done, I'd do it again. I got the transfer case and hand brake covers from them a couple of years ago - holding up great.
