Center Dash Door Lock Switch Issue
Old Nov 30, 2012 | 09:39 AM
VTrex09's Avatar
6th Gear
Originally Posted by lr2001silver
Removal and replacement of passenger area fuse panel/IDM:
step one; open bonnet & disconnect battery.
Step two; open driver' s door, using a flat head screw driver turn two plastic screws on panel under steering wheel. ( counter clock wise)
Step three; unplug the plugs on front side of fuse panel.
Step four; at the top of the fuse panel you will find one 10 mm nut remove that.
Step five; now that the fuse panel is loose lift up on it gently as there is a 1 inch plastic stub
On the bottom that fits into a hole.
Step six; unplug all plugs on back side of fuse panel " some are pretty tight" these plugs can only plug into one place so don't worry about marking them. (Its goof proof)
Okay almost done now go in reverse and install your new fuse panel.
When these fail they can cause some strange electrical issues.
This is a great write-up, thank you. Hopefully I'll have time this weekend to look into it. Thanks again for everyone's help.
Old Dec 5, 2012 | 06:08 PM
tedw's Avatar
4wd High
Well, the good news is that I was able to get a replacement fuse panel (thanks to Paul) and that was definitely the cause of my central locking and CD player issues. The bad news is that I am having an issue with the security system now and cannot start the car (immob). I have unlocked manually and with the fob, but that is no help. Suggestions?
Old Dec 5, 2012 | 06:36 PM
tedw's Avatar
4wd High
I did some more digging in the forum and turned the key forward for a few minutes to let it sync and all is fixed. Good as (almost) new!
Old Dec 13, 2012 | 08:49 AM
roverboy101's Avatar
i need help i have an 02 discovery and it will start and run fine half the time then the next itme i try to start it it will crank but wont start i also cant hook my scan tool to it so any help would be great
archaeology_student
Feb 11, 2015 09:49 PM
lr2001silver
Jul 16, 2012 02:27 AM
faversham
Aug 23, 2009 09:30 PM
CandiMan
Aug 24, 2008 10:35 PM
