Stuck Fuel Door Switch on Dash
Old Aug 19, 2009 | 05:59 AM
faversham's Avatar
Default Stuck Fuel Door Switch on Dash
1996 RANGE ROVER 4.6 HSE.
The dash-mounted switch above the wheel for the fuel filler door is stuck in down position. Is there any way to free this switch and/or get the fuel filler door open? Need help bad!
Thanks, Faversham
Old Aug 19, 2009 | 08:59 AM
rr95's Avatar
You can manually open the fuel door by removing the rear inner panel which will give you access the the inner mechanism.
I have never had cause to remove the switch but it should just pop out with a little gentle prying. Give it a good squirt of contact cleaner and see if that frees it up.
Chris.
Old Aug 23, 2009 | 09:30 PM
mlshelton's Avatar
Rover connection sells the part, it's relatively cheap and easy to install.
Open the door for now as the above post said via the fuel door, or - once you pull out the old broken switch you can just jump across the 2 wires there with a short piece of wire for contact.
ImQuattro
May 1, 2014 08:36 PM
hoseb15
Dec 17, 2013 10:08 PM
VTrex09
Dec 13, 2012 08:49 AM
Glwoll
Mar 23, 2012 06:30 AM
smyevich
Aug 31, 2006 01:31 PM
