CHANGE ECU and CLUSTER.
Old Mar 22, 2022 | 09:53 AM
muffin man's Avatar
Question CHANGE ECU and CLUSTER.
hi. soon I will change ecu and cluster of a disco II 2001 to disco II 2003........the parts I want to change: ECU, BCU, ignition coil and I have a question about IDM (fuse box) is also necessary for this change ??
if you have other observations of this change.
Old Mar 22, 2022 | 09:58 AM
Alex_M's Avatar
No, fuse box is not tied in with the ECU.
Old Mar 22, 2022 | 09:59 AM
ahab's Avatar
Isn't that a 4.0 to 4.6 conversion as well?
Old Mar 22, 2022 | 10:11 AM
muffin man's Avatar
thank you Alex_M !
Old Mar 22, 2022 | 10:14 AM
muffin man's Avatar
no. I have a disco II 2003 immbolized (alarm problem).....and I have another 2001, I will pass you the boot components to be able to move the 2003.
Old Mar 22, 2022 | 10:15 AM
muffin man's Avatar
Default no....the problem in 2003 alarm
Old Mar 22, 2022 | 10:58 AM
Alex_M's Avatar
Ok, for an '01 to '03 or vice versa you will also want to change the MAF sensor and intake box lid. They are different sizes.
Are both of these trucks equipped (or unequipped) with SAI?
Old Mar 22, 2022 | 06:55 PM
Extinct's Avatar
If you don't swap the IC with ECU/BCU your odo is going to flash. If you don't change the inside fusebox you will need to turn the ignition on and leave it on for 20 mins to allow the IDM and BCU to sync.
Old Mar 22, 2022 | 11:56 PM
muffin man's Avatar
Alex_M.........I dont think have a problem, because this 2003 disco II is from an agency in my country and comes with a 4.0 engine. this has caught my attention. but it totally suits me for the change of ecu and others. the disco 2001 have 4.0 engine. but tomorrow Ill see how this really is.
Old Mar 22, 2022 | 11:59 PM
muffin man's Avatar
Default interesting data
ok....really is interesting data. thkkk......what is the IC ???
