Changed Alternator, now Blinking M and S..
Old Apr 9, 2014 | 12:04 PM
Rocko99's Avatar
Default Changed Alternator, now Blinking M and S..
Had an alternator go out on my 2000. It went into limp mode before I made it home to change it. Swapped it out, Alternator is working fine, but the M and S lights are still flashing and it's still in limp mode. Any ideas?
Old Apr 9, 2014 | 12:06 PM
ralphobell's Avatar
Your battery is below 10 volts? Are you sure the alternator is charging? Did you hook up the small red wire to the back as well? Just some quick thoughts.
Old Apr 9, 2014 | 06:03 PM
Rocko99's Avatar
I guess battery was not quite charged enough. Started fine but I hooked it up to the charger for an hour, ran the truck, lights out. Thanks.
Old Apr 9, 2014 | 07:50 PM
04duxlr's Avatar
Your alternator should charge your battery way faster than any charger. Keep an eye on it. If it's a reman from a chain store it may be bad.
Old Apr 9, 2014 | 08:56 PM
ralphobell's Avatar
Get ready to replace the battery. If you ran the truck so long that the battery drained that low, your more than likely going to have issues. Same thing happened to me less than 2 months ago.
Old Apr 9, 2014 | 09:17 PM
jfall's Avatar
Battery 3 to 4 years old.
Replace it with Walmart new battery.
New Alternator could be bad.
Make sure wires are attached correctly to alternator.
Make sure the belt is not slipping on the alternator and is routed correctly.
Old Apr 10, 2014 | 05:58 PM
Rocko99's Avatar
Thanks. I will suggest that. Battery went through the ringer in the last month. It's leaking a bit on top as well.
Old Jul 29, 2014 | 02:55 PM
sstevensonm's Avatar
How hard is the alternator to change
Old Jul 29, 2014 | 03:03 PM
dusty1's Avatar
Quik n easy
Rave if you need directions
Post #5 has rave in sig
Old Jul 29, 2014 | 03:17 PM
Jared9220's Avatar
Instructions:
How to change Alternator.pdf
BHamms
Nov 29, 2013 10:15 PM
Sanriogonz
May 23, 2012 11:27 PM
dh42891
Jul 26, 2010 12:37 AM
SpeedAgent
Jul 12, 2007 07:34 AM
