Changed fuel pump !!!
Old 11-27-2008 | 04:25 PM
mrsbntn's Avatar
Default Changed fuel pump !!!
okay I changed the fuel pump & I have fuel in the lines & pressure but it will not start almost like it is flooding ..... It's a 98 disco I does anyone have any ideas ??? any would be great!!!!!!!!!!!!
George II
Old 11-27-2008 | 08:07 PM
Default RE: Changed fuel pump !!!
Check for spark.
Old 11-28-2008 | 08:09 AM
Sounds like a fuel pump wasn't needed. What exactly is the engine doing? Have you pulled the plugs to see if they are wet or not?
You may have a bad crank sensor that will not allow the injectors to fire.
Travelor
09-24-2015 06:11 PM
ssrhythm
06-20-2015 05:25 PM
cipher982
11-30-2011 09:12 AM
JumPeR04
04-07-2011 09:52 PM
Whitepine
06-05-2010 09:36 PM
Quick Reply: Changed fuel pump !!!
