Changed rotoflex and Watts linkage - now a hot/friction smell
Old Jul 1, 2017 | 07:32 AM
Red5's Avatar
I agree, they will not coast in the SAME direction with the brake on, but they will (and should) spin in opposite directions. But, maybe I'm missing something, late night and this AM is a bit fuzzy.
Old Jul 1, 2017 | 10:24 AM
The Deputy's Avatar
Release the parking brake and see if you can spin both rear wheels easily. You may have a caliper hanging up.
Brian.
Old Jul 1, 2017 | 01:32 PM
mollusc's Avatar
Pretty sure it's not a caliper. The wheel that wouldn't rotate would move slightly back and forth -- play in the diff. It wasn't completely immovable.
Old Jul 1, 2017 | 03:02 PM
Best4x4's Avatar
Sounds like a broken axle shaft. If one wheel spins with the ebrake on and one does not, when you release the ebrake the wheel that wasn't spinning should. Also with both wheels off the ground you should be able to rotate a wheel and have the other side rotate the opposite direction as mentioned earlier.
Old Jul 1, 2017 | 09:24 PM
mollusc's Avatar
I was coming to that conclusion myself, too. Will do some more diagnostics tomorrow -- e-brake on, off, etc.
Anyone have any idea how much a replacement half-shaft is going to cost?
Old Jul 1, 2017 | 09:48 PM
Best4x4's Avatar
Shouldn't cost much at a pick n pull
Old Jul 1, 2017 | 09:56 PM
OverRover's Avatar
New, $500 and way up. Like > AXLE SHAFT - RH REAR DISCOVERY II, RND690, TOD100020 - Rovers North - Classic Land Rover Parts
Used (I'm shocked at these prices) > Discovery Rear Axle Shafts
abran or Paul Grant can probably help you out as well.
Old Jul 2, 2017 | 05:57 AM
mollusc's Avatar
No pick-n-pulls anywhere near me, but those Roverland prices are making me happy.
Old Jul 3, 2017 | 10:25 AM
mollusc's Avatar
Okay, I don't think it's a half-shaft either. But I'm definitely not happy.
Up on axle stands, in neutral, with parking brake off (front wheels chocked, naturally).
- If I spin the driveshaft, both wheels will turn
- If I spin either wheel, the other wheel will rotate in the opposite direction and the driveshaft will rotate
- However, I can hold any of the three points stationary (driveshaft or either wheel) and still rotate the other(s) in either direction
So... it certainly seems like my rear differential is screwed. In order to be able to move the truck around I have removed the rear driveshaft and locked the CDL.
If I pull the diff apart and the half-shafts are in good shape, does it make sense to replace the entire rear axle, or just do the crown assembly?
Old Jul 3, 2017 | 10:34 AM
Best4x4's Avatar
I'd just find a good used center section (if I remember correctly the F/R are the same. Paul or Abran should be able to hook ya up with a good used unit.
toad2
Nov 25, 2014 04:25 PM
MattyJ2000DiscoII
Mar 12, 2014 11:13 AM
AdrenalinPlease
Mar 15, 2013 11:00 AM
04BluDisco
Mar 13, 2011 08:20 PM
WindrockRover
Dec 10, 2010 08:09 AM
