Changing Brakes....tires wont budge!
Old Apr 29, 2008 | 08:42 AM
  #21
Default RE: Changing Brakes....tires wont budge!
Most tire shops have the torque specs in their computers, they won't of course have it for a steel wheels. I would still go for 100#'s.
Old Apr 29, 2008 | 02:50 PM
  #22
Sfef84's Avatar
Yea.... I felt like an idiot when I couldnt even figure out how to get the wheels off of the disco considering I was installing my OME lift. I didnt look through the entire topic but here is what I did.
1) Went to autozone and purchased a 27 or 28mm (call land rover) socket
2) move the socket around to see where it gets the best hold on the aluminum over the lugnut
3) tapped (and sometimes whacked) the wrench with a rubber mallet far enough to get a good fit
4)before the entire lugnut is off, take off the wrench and either wiggle or tap (or whack) the socket off
5) repeat
6) same deal when putting them back on
Hope this helps
Old Apr 29, 2008 | 03:48 PM
  #23
unstable's Avatar
I recently encountered a front wheel that was frozen to a hub. I beat it with a mallet and ended up breaking the handle...then I had a minor stroke of genius.
I tightened the lugnuts back onto the studs, very loosely. Dropped the rig back down onto the ground and moved the steering wheel from left to right. Jacked it back up and pulled the wheel off without effort.
robdis96
Feb 18, 2013 01:08 AM
Disco Buddy
Jan 30, 2013 06:55 AM
ruffram
Oct 20, 2012 12:12 PM
twaszak
Nov 26, 2010 01:41 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
